Partial Scenery Redo (FINISHED)
Plastic Or Wood
All Things Track Building!
Postby dw5555 » Sat Jan 12, 2019 3:29 pm
After 3 yrs of redoing this end of the track I've finally got around to putting the landscaping back in. I had this POS Styrofoam lying around and I hate it but you use what ya got. It obviously carves easy but those little Styrofoam balls get everywhere. I have 3 areas to do but this is the biggest. I only raised it because I want to incorporate an H.O size building into the track so I needed to get it away from the track to make the scale a little less noticeable. Again not ideal but again ya use what ya got. I got the foam rough cut and I brushed on a layer of Plaster of Paris. It actually covered a lot of the seams with the 1st coat. I'll let that sit for the night and get another coat on tomorrow.
Dave
dw5555
Re: Partial Redo
Postby TuscoTodd » Sat Jan 12, 2019 4:46 pm
Looking good sir!
Re: Partial Scenery Redo
Postby dw5555 » Mon Jan 14, 2019 2:06 pm
Roughed in. Next step plaster of Paris and towels.
dw5555
Postby HomeRacingWorld » Mon Jan 14, 2019 2:30 pm
You are really getting after it!
Postby RichD » Tue Jan 15, 2019 7:51 am
You might look into using plaster cloth, that is not as messy as having to spread plaster over everything.
Postby dw5555 » Tue Jan 15, 2019 10:48 am
Agreed Rich, plaster cloth is wonderful but again ya use what ya got. I have the plaster and paper towels.
Dave
dw5555
Postby Dundee Denny » Tue Jan 15, 2019 8:06 pm
The elevations will add lots of character to the track, you can see what difference it will make at this very early stage!!!
Look forward to the continued magic of your mountain building!!
Dundee
Denny
Dundee Denny
Postby dw5555 » Wed Jan 16, 2019 11:12 am
This is good enough for government work. Plaster is dried so now to throw some paint on it.
dw5555
Postby dw5555 » Wed Jan 16, 2019 1:44 pm
Another step closer.
dw5555
Postby Almafan 55 » Wed Jan 16, 2019 2:27 pm
David, your making a big mess as always!!!! You better get your wife to do it! :laughing-rolling:
Almafan 55
Postby dw5555 » Wed Jan 16, 2019 2:29 pm
I've missed you Rob.. :shhh:
dw5555
Postby dw5555 » Fri Jan 18, 2019 12:45 pm
1st layer down. Let this dry and then do a fill in and more texture. Even got a layer of gravel on the hilltop for the factory.
Dave
dw5555
Re: Partial Scenery Redo (FINISHED)
Postby dw5555 » Mon Jan 21, 2019 6:35 pm
Finally done. I can keep it intact until May when the grandkids come up for their week visit. After that no guarantees. :o To think this was all done just to add the H.O. scale building at the top of the hill to make it look less like it doesn't belong.
Dave
dw5555
Postby 4424ever » Mon Jan 21, 2019 6:46 pm
Well it may have seemed like a lot of work the outcome is outstanding :music-rockout:
4424ever
Postby 3nickel » Thu Jan 24, 2019 6:30 pm
Looks awesome Dave.
3nickel
