Home Racing World • View topic - Scx pod
Scx pod
Scx pod
Postby Racie35 » Thu Jan 24, 2019 2:24 pm
Is there anyone making pods for scx cars...non pro pod and with 130 motor?
Racie35
Re: Scx pod
Postby chappyman66 » Thu Jan 24, 2019 5:04 pm
I am slightly confused.
Most regular SCX cars don't have a pod at all. In order to install one, you have to cut up the chassis (not a huge loss). But if you do that, there are plenty of pods available.
If you want to convert the SCX motor to an FC-130 without changing the chassis, Slot.it makes the parts but there are options for printing them as well (Thingiverse again).
Maybe my SCX cars are just too old and the new ones have a pod?
Re: Scx pod
Postby Racie35 » Thu Jan 24, 2019 6:46 pm
They have one that rolls left to right....older cars didn't.....I'll look for a picture to show
Racie35
Re: Scx pod
Postby Racie35 » Thu Jan 24, 2019 6:49 pm
Here's a few pics
Racie35
Re: Scx pod
Postby Wobble » Thu Jan 24, 2019 11:12 pm
The Slot.it SISP08 adapter allows use of a FC-130 motor in the regular RX pod but won't work in a pod for RK motors
Wobble
Re: Scx pod
Postby Racie35 » Thu Jan 24, 2019 11:16 pm
I was hoping someone made one that fits the 130 moving it back enough...but yes, I've got the adapters for the other..
Racie35
Re: Scx pod
Postby arroldn » Fri Jan 25, 2019 12:38 pm
Racie35,
I should have a pod or two. How many do you need?
Arrold
arroldn
Re: Scx pod
Postby Wobble » Fri Jan 25, 2019 1:43 pm
Also might be of interest to you. If you can get your hands on a RK42 pod a FK180 motor will slip in with a wee bit of modification to the front motor mounts to allow for the motor contacts. I put a Ninco NC2 virtually straight in a Cuda with the RK pod and just had to add a couple of wires.
Wobble
Re: Scx pod
Postby Racie35 » Fri Jan 25, 2019 4:50 pm
Racie35
Re: Scx pod
Postby Racie35 » Fri Jan 25, 2019 4:51 pm
Racie35
Re: Scx pod
Postby Wobble » Fri Jan 25, 2019 8:26 pm
Wobble
Re: Scx pod
Postby 4424ever » Fri Jan 25, 2019 9:34 pm
A Colgate motor will fit those pod too, snicker snicker
4424ever
Return to 3D Slot Forum
