Any advice on removing stripes from Carrera track?
Re: Any advice on removing stripes from Carrera track?
Postby kctess17 » Sun Feb 03, 2019 11:03 pm
i dry brushed my carrera track with flat black paint from the samples you get at lowes.now the white lines and the red and white borders look like they are old and weathered. you can go as heavy or lite as you want.
kctess17
Postby 32lbking » Mon Feb 04, 2019 1:05 am
DW5555 used rustoleum spray paint to cover lines on his Carrera track. It was a very good match. I believe it was Rustoleum Aged Iron. I'm sure he will see this and chime in.
Randy
32lbking
Postby Czar » Mon Feb 04, 2019 5:57 am
If some of your track is already painted you can take a piece of track to a professional panting store and they can scan the track section and match the color of your "Sebring concrete".
Czar
Postby buspor63 » Mon Feb 04, 2019 10:25 am
I used a Dremel and cut all of mine out....... Too soon, it's not April 1st yet ..lol
buspor63
Postby WB2 » Mon Feb 04, 2019 7:43 pm
The model railroad guys use Solvaset and an erasure to take off tampo printing.
Soak the printing with the Solvaset, wait, reapply, rub gently with erasure.
Better yet, let your fingers waddle over to Google and type in ‘remove Tampo printing’.
Lot’s of ideas there.
I cannot recommend Goof Off. I tried that on AFX track and it removed the texturing.
One method is to use a dry erase marker. It looks like they keep smearing it on and wiping it off until the markings are gone. https://liveandletdiecast.kinja.com/dry ... 1751498338
Please let us know if you have any success.
WB2
Postby WB2 » Fri Feb 08, 2019 1:37 pm
Looked back to see if there was any success.
I noted the OP mentioned 70% alcohol. 90% is what I use for paint stripping.
Walking through a hobby shop I noticed Scalecoat II Wash Away Paint Stripper is still available. The product won’t harm plastic but I’m not sure if it will remove Tampo printing.
WB2
Users browsing this forum: Google [Bot] and 0 guests
