Put the finishing touches on the NASH
Started as a $10 slosh casting from 873chris on e-bay.
Had to sand it quite a bit 'cuz It was cast from a 3-D print I think.
A couple heavy coats of primer between sandings resulted in this starting point.
Built a 3/64 brass rod chassis.
Getting kind of lazy & built a cage around the Piranha with a dab of solder to hold it in place.
(Just need a soldering iron instead of a screwdriver for motor install/removal) :D
A little Dremel work, some Bondo, two coats of Ace Hardware white primer & one coat of Ace Hardware red.
Home-printed decals, Cox gears, Pro-Track wheels, home-cast urethane tires & Parma guide with Big Mama braid.
.............I just need to know what mod body Tusco Todd would like........ :?
