carrera digital control unit
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby rudyroo » Thu Feb 21, 2019 9:30 pm
does anybody know what the max volts is for running carrera digital 124 scale cars is, i have been frying cu units been running about 23 to 25 volts does that amps matter were too set
rudyroo
Re: carrera digital control unit
Postby buspor63 » Fri Feb 22, 2019 4:52 am
I stay around 18.5 volts going in, that's what the Carrera power supply is rated at. Amps could be a problem, the track will only pull as many as needed. The cars themselves don't pull much, but if you have a short, the track could pull as much as available. I have a 10 amp PS, but put a 7 amp fuse in, I'm told the CU will handle 8 amps, but just under is better.
buspor63
Postby Cincyslots » Fri Feb 22, 2019 6:48 am
i'm with bus, 18.5v not more than 19v
bruce
Cincyslots
Postby dw5555 » Fri Feb 22, 2019 10:08 am
This is cheaper than CU's. Almost fished my motor comparison test. Interesting results.
Dave
viewtopic.php?f=30&t=20380
dw5555
Postby edmagner » Fri Feb 22, 2019 10:31 pm
I dance right on the 19v line....have not lost a CU...
edmagner
Postby 32lbking » Sat Feb 23, 2019 12:18 pm
I set mine at 20-22v according to the meter on my power supply when running stock motored D/124 cars. I have not checked the voltage at the track to see the actual voltage at the rails.
Some of my D/124 cars have 12v motors and when running them I run around 17v.
Oh, almost forgot 10 amp PS with a 6.5 or 7a [I can't remember which :think: ] fast blow fuse between the PS and CU. The fuse is a must have just to be sure.
Randy
32lbking
Postby BRS Hobbies » Sat Feb 23, 2019 12:57 pm
I would say the upper limit (voltage wise) for the control unit is 18 volts. You might get away with a volt or two above that but 23 to 25 volts is definitely too high.
Best regards,
Brian
BRS Hobbies
Postby dw5555 » Sun Feb 24, 2019 9:52 am
LOL, he hasn't been back since he posted his question. My question was going to be what are you running that you need that many volts and maybe their hopped up motors?
Dave
dw5555
Return to HRW 1/24 Scale
