Home Racing World • View topic - 2019 CanAm - Round #1 - The River Run
Re: 2019 CanAm - Round #1 - The River Run
Postby arroldn » Wed May 08, 2019 7:50 am
I've got to work on the loose tail out symptoms with my cars. They all tend to have this issue. Either more weight on the back end I guess or keep working on rear tire profile. Where is that Chassis Engineer? :think:
arroldn
Postby Changing-Gearz » Wed May 08, 2019 9:29 am
Annnnnnnnd - First among the inline pod cars! Oh, wait a second....
Interesting comments on the 25... I suspect the chassis isn't stiff enough - but I guess I'll find out Sunday...
Good luck to everyone!
Changing-Gearz
Postby gascarnut » Wed May 08, 2019 10:25 am
gascarnut
Postby arroldn » Wed May 08, 2019 11:34 am
Thanks for the tip. So I've been doing wrong all these years. Dang. :think: I always thought it was to get as much weight close to the rear axle.
arroldn
Postby Cgyracer » Wed May 08, 2019 12:32 pm
Thanks Allan for the qualifying, looking forward to the race! Nice pictures and great reporting, going to be a good race.
Rob
Cgyracer
Postby arroldn » Wed May 08, 2019 12:59 pm
Gascarnut,
I've read the 40/60 ratio front to rear. Which is how most of my cars have been set up. I think RichD in an article on how to set up a car said if the car rolls over you need weight lower. If it slides to much add weight higher up. Now I'm going by memory at this time. I have the article saved on my computer at home. Guess I'll be in the chassis shop this summer. Maybe too late for some cars but maybe better results for 2020.
arroldn
Postby Smokeio » Wed May 08, 2019 2:01 pm
Maybe it's not the weight? Check to make sure your front end is setup correctly, your pod isn't too loose and doesn't twist, or your tires do not interfere with the body.
If all else fails, twist the fargal pin counter clockwise for loose conditions. Don't forget CARGOFAST Slot Car Racing Products sells STAYONTRACK which works perfectly for loose. I'm sending some to my pal Dennis to help him in the chassis shop this summer.
Smokeio
Postby DRW21 » Wed May 08, 2019 2:09 pm
Thank You Bob for driving duties.
Also to Allan for getting this awesome proxy underway, what a great field, I'm honored to be in this series.
Race day will be the big test of course as it always is and we are all looking forward to that.
If any one wants some set up tips, e-mail me dr86cwest@outlook.com and I'll get around to showing what I have done and why, it will take some time to get back to you but I will share info.
I work with this theory - If you don't help other racers then who will you be racing with in 2 years time. Best to help others to boost the hobby.
No secrets, just show and tell what works for me.
All the best for all competitors.
Cheers Guys - Dave
DRW21
Postby arroldn » Wed May 08, 2019 3:16 pm
Dave,
I will definitely be sending an e-mail since you definitely brought your A Game. 8-)
arroldn
Postby Audi1 » Sat May 11, 2019 6:37 pm
Gentlemen, we are racing tomorrow morning!
Good luck to all!
Postby arroldn » Sat May 11, 2019 10:38 pm
Smokieo,
Thanks for the tips. Pod too loose, tires and body contact, front end. Will examine more closely. I have caught tire contact on some returning cars.
What is the advantage of the pod? If you have a podded car should the body screws be loose as well? My cars seem to run faster with both loose. I recall in a post by someone, maybe it was you, that they were going to tighten the body screws and just adjust the pod.
arroldn
Postby wanabgts » Sun May 12, 2019 9:32 am
Raceday!
Zack
wanabgts
Postby ALS » Sun May 12, 2019 10:43 am
Racers Start Your Engines The Season Starts today . Good luck to all the Builders the car are outstanding. Adrian ALS
ALS
Postby Smokeio » Sun May 12, 2019 10:46 am
Smokeio
Postby Audi1 » Sun May 12, 2019 11:51 am
We have a winner!
Return to 2019 Can-Am Proxy
