Body's paint-detailed and mounted to the chassis. Ended up just attaching with the two front screws.
Got the body stance with the tires just barely tucked in under the wheel arches. Had to round off the front tire edges on the driver side to eliminate tire rub. Like this look on my slot car but wouldn't do this on my 1:1 Mini especially with our local pot-holed streets. Four seasons weather is tough on road surfaces here.
Gave it a run on my short and twisty wood track and got a big improvement for fast lap from last year's test. Almost 2/10ths of a second better. Must be the fresh urethane tires that helped.
No complaints as it's now my fastest 1/24 build and is so driveable through the corners like the real thing.
