by JESIV » Sat Jul 27, 2013 11:43 am
Baford - I definitely plan on doing scenery all around. Lane 1 is 74.84' and lane 2 is 76.69'
Dan - The long straight is 12.5'. Feel free to bring the scenery stuff with you when you come over. Every little bit helps.
David - The problem with the garage is that there is no insulation and no ventilation. So it feels like the air is 'trapped', especially at the end away from the door. So the summer's temp is about 10deg hotter than outside and the winter is about 10deg colder than outside. I've done my best to insulate the metal garage door and it helps a bit. I've tried a small electric heater but with a space this large (the garage is 24' long x just over 13' wide and the ceilings 12' high) it doesn't do much. I also have the issue of tripping the circuits if too much juice is being used (microwaves and vacuum cleaners go to war for power in my place, lol) so larger electric heaters wouldn't work. The final roadblock is that I rent, so I can't just go cutting holes for vents and re-wireing to run a heavy duty outlet to the garage....well I guess I 'could' but I don't feel like I should. I'm open to suggestions if you (or anyone) have any. To the track - I'm really pleased with how close the layout looks to the real one, it's one of my faves too so I was glad to able to pull it off.
