Before researching what components to use on the upcoming midget proxy, I had never even heard of gear pitch. Then I began to see "48 pitch" mentioned in reference to certain Parma and other 1/24 scale gears. That sent me on a quest to uncover exactly what "pitch" means.
From what I understand, gear pitch is the number of teeth on a given gear over the span of one inch. Basically, to find out a gear's pitch, you can either cover the gear in ink and roll it over a sheet of paper, or roll the gear through something like silly putty. Either way, you then measure one inch in length and then count the number of tooth impressions that you see. Ta-dah! That's your gear's pitch.
The reason that this is of interest has to do with what is commonly referred to as gear mesh. Gears with the same or similar pitch mesh well, whereas ones with dissimilar pitches may struggle to get along, often resulting in anything ranging from a minor inconvenience such as noise to the very much unwanted resistance.
The difficultly in pinning down exactly pitched gears is that it seems the pitch varies even throughout a given manufacture's line. Slot.it pinions seem to vary between about 47 through 60, and NSR pinions vary between 45 and 60. The variance comes in to play not only due to the amount of teeth on a gear, but also in its diameter.
It seems that gear pitch is something of a concern in the larger scales, (and the R/C world) but I have yet to find a 1/32 manufacturer who publishes this information. So, my question is this- is it worth going nuts over, or should I just forget the math of it all and just play around with various gears until I find a mix that fits a given application?
My problem is that I often need to know how something works, instead of just that it does. Perhaps that aspect of my personality is causing me to lose my mind over this…
:confusion-questionmarks:
