After patiently waiting for this car to arrive, I ended up purchasing the Pioneer Sunoco car from Pendleslots in the UK. I got great service from them as always!
When it arrived on October 7th, I opened the box to find that the cardboard wrapper that has the car details ripped off on one side. No biggie for me, but not a good omen. The car was fastened to the base with a screw put on with what appears to have been an air wrench. I immediately put it down next to the car that started me off in 1:32 - the Scalextric 1969 version - yes I realize this is a bit apples to oranges in comparison, but it has to be made - afterall the plan is to race them together:
Initial Testing: I did a cursory once-over and put it on the track. The nicest thing I can say is that it made it around the track...barely. The gears sounded so bad that it made a Revell Stocker seem quiet in comparison. It was noisy to the point that my wife called down from upstairs to ask what I was doing...something that NEVER happens. Did I mention the wheel hop? Peter Cottontail has nothing on this car. It also had no traction, but that is normal for my track with stock tires.
The Bodywork:The paint is sub-par and they only shot it from the top and sides – it fades in color towards the rockers.
The underside and the bottom of the body is gray. Whoever painted it missed it completely.
The blue is also very dull on my car with almost no shine and several rough areas. BTW - another HRW member has one that is a much lighter shade of blue - and his clear coat has not properly cured - if he touches it he leaves fingerprints. The good news is the bottom of his was painted.
The Tampo:The yellow is muted – it looks thin and is no doubt due to the blue it went over. The tampo is ok – not great. It seems to have a rough finish over the tampo or the tampo itself is rough. The tampo is also off from one side to the other. It is so bad that on one side the 302 letters are above the belt line and below it on the other side. The stripes do the same thing from side to side in relation to the door handles. Additionally, the tampo has numerous smudges as you can see in the above picture in the #15 roundel.
Under the Hood: Back to the running...the car is rough. Ok, I can tune it...once I get the screws off that were put on by the tire crew on Jr’s car...and here's what I found:
1) The body and chassis are slightly twisted. Look at the wiring pics...they were under the interior and pinched where the screws went through the round hole in the chassis into the interior (not used here) on the Mustang...pinched it good too. So, it never sat on the chassis correctly.
2) The wheels – both rear wheels were as wobbly as a drunk in a Walmart. In looking at them, it was very obvious that they were not properly centered when drilled or molded - however they were made.
3) There was NO lube anywhere on the car. And those nice brass bushings with the oiling hole? Once was turned so you couldn’t use it. Had to pull the axle and rotate it. Not a big deal, but just added to the feeling that it wasn't well put together.
4) The front axle had issues too. There were 3 spacers on each side and it still had excessive side to side slop that caused the tires on both sides to contact the fenders on corners.
5) The back axle had an epic amount of slop on top of whatever else was going on with the mesh.
So, what to do? Box it and put in on eBay, or run the crap out of it. Hmm...I choose door number two - after all, I'm almost $77 into this thing with the exchange rate...
The Fixes:1) I replaced the entire rear assembly with Slot Car Corner 15x8 insert wheels (I've turned down the original wheels for inserts) and a new Slot.it gear. The only saving grace to the loose wheel issue is that the SCC and Slot.it parts worked perfectly so I didn't have to do the axle and bushings.
2) I re-routed the wiring so that it doesn't pinch the chassis or interior. I also sanded off the old screw mounts on the bottom of the interior to help with that.
3) I noticed that one of the braids wasn't seated right - whoever inserted the blade with the wire soldered onto it must've fought with it...it looked like it had been bent multiple times and broke as soon as I touched it. I had to solder the wire on the "stub" that was remaining.
4) Not a Pioneer issue, but I replaced the rear tires with PG XPG tires and sanded the chassis all around and opened the mounting holes up to get some float.
5) I carefully removed one wheel off the front axle, trimmed it, and set the width correctly since the wheel was unable to slip on any further.
So, how is it now? It runs like a $76.58 car with $20 in parts in it- in other words; really good, now that I've done all of that. Mine needed more than a simple tune - wheels and gears should not have to be replaced on a brand new car. This isn't Fly 10 years ago with the cracked pinion issue. This is 2013.
So there you have it. Your mileage may vary.
BTW - Pendles seems to have these in stock again if you still can't get it in the USA.
