by Czar » Fri Nov 22, 2013 7:43 am
When adding jumpers it is not the length of track that matters, it is the number of track joints. The track itself has very, very little resistance (resistance is why you use jumpers). It is the joints that introduce the resistance that robs you of even, consistent voltage around your circuit. You will be just fine if you place jumpers at every 15 - 20 track joints. So, a section that has several 1/4 or 1/2 track pieces will need a jumper in a shorter distance than if you have full size track pieces.
