by masmojo » Tue Feb 11, 2014 4:15 pm
Trev, I think you are making a good choice, Carrera track is probably THE way to go! You can start with an analog set and add the digital later OR get a digital set and add track and a D132 black box later. Any way you go I would stay away from the Carrera 1/24-1/32 track It's HUGE! And unless you have a large room it will limit your options, the ONLY good thing about a 1/32+ scale track is being able to run 1/32 or 1/24 scale cars, which makes sense if you have a bunch of those, but is a bit silly if you don't .
The footprint of most 1/43 scale tracks is not much different to HO; you can fit a much more complex (and interesting) layout AND still have space for scenic elements, Which if your coming from O gauge you probably have allot of Scenics and they work so well with this scale. Most of your trees and building will be quite @ home next to these cars.
It would be important to note that although Carrera track is THE track of choice in this scale if you REALLY want to hang the back end out round the corners you will need to buy cars from other brands, SCX, Kyosho OR modify your Carrera's OR build your own!
Anywayz settle in and relax, because 1/43 guys are the most laid back, easy going and helpful on the internet! :whistle:
