Home Racing World • View topic - Go!replacement chassis, fully customicable - it´s running!
Postby pfuetze » Wed Feb 19, 2014 4:11 pm
Finally i found the time to design a chassis that will use Go!components. Wheels and crown gear do not have to be removed to be used in this chassis. After pre-assembly, the axle holes need to be drilled out with a drill bit fitting the Go! axles size (2.2 or 2.3mm, i have to try this)
Motor and axles are fixed by screws (M2 or kyosho screws or similar size)
wheel base, front/rear width, chassis width and height of the body plate can be specified.
Rear body mounting is optional, normally the chassis will come without it. Mounting the body on the side is working better for driving.
One thing that i´m quite proud of: the height of the magnet can be adjusted by screws (a little similar to the deslots). In this way the downforce can be adjusted.
The chassis will fit all go!tires, from a Mini (15mm) up to the old corvette wheels (20mm)
minimum and maximam dimensions:
standard measurements:
ready for printing:
I will order one of those for my green Go!Mustang and report more ...
Peter
Re: Go!replacement chassis, fully customicable
Postby LloydL » Wed Feb 19, 2014 5:28 pm
Another very useful chassis from you Peter, well done!
Regards, Lloyd
LloydL
Postby Dodgefarmer » Wed Feb 19, 2014 5:47 pm
Thank you Peter. :text-thankyouyellow: :clap:. I have 2 questions . 1st and foremost PN please. 2nd is the chassis adjustable for the different wheel bases or do we order the chassis specific for the bodies that we are working on.
Randy
Dodgefarmer
Postby Alan132 » Wed Feb 19, 2014 6:24 pm
I am new to this type of chassis. What is the procedure in obtaining a few? Are there others available?
Details please.
Thank you
Alan
Alan132
Postby pfuetze » Thu Feb 20, 2014 1:30 am
Postby Datto » Fri Feb 21, 2014 2:47 pm
That looks super, Peter! :banana-dance:
Datto
Postby martin0409 » Fri Feb 21, 2014 3:53 pm
Very well designed chassis Peter. What is the chassis going to be made of? I've read somewhere (correct me if I'm wrong) in this forum about you doing blue printing and I have seen on TV on a bigger scale how it was done and it's truly amazing. I'd like to see the chassis when done and would like to try one in the future.
Martin
martin0409
Postby pfuetze » Fri Feb 21, 2014 4:50 pm
Martin, i let them print on a rapid prototyping printer @ shapeways. there are some different printing methods for different materials. For chassis, i always order the "white, strong and flexible". there is more info on the shapeways website.
Thanks for the flowers!
Postby Alan132 » Fri Feb 21, 2014 6:25 pm
Peter,
So what is the procedure to obtain? Turn order into you? Turn order into Shapeways? Method of Payment? Cost?
Thank you
Regards - Alan
Alan132
Postby Cjent » Sun Feb 23, 2014 7:07 am
I will get you an email soon! YAHOO!!!!!!!!!!!!!!!!!! Great for Digital builds. :text-thankyouyellow: :music-rockout:
Cjent
Postby Tigeracer » Sun Feb 23, 2014 8:15 am
In a word... AWESOME
Tigeracer
Postby WB2 » Sun Feb 23, 2014 10:10 am
Does the guide use standard braid and ferrules?
WB2
Postby Broman62 » Sun Feb 23, 2014 10:52 am
Postby pfuetze » Sun Feb 23, 2014 11:10 am
Postby Alan132 » Sun Feb 23, 2014 6:57 pm
Hello Peter,
What is minimum and maximum measurement of the entire chassis from front of guide holder to rear of chassis?
What is the size of the section of the guide that fits down into the slot of the track?
Sorry for all the questions but I will be doing something a little different with them!
Really looking forward to them.
Looking at about 5 or 6 different ones to start!
Thank you again
Alan
Alan132
