by masmojo » Tue Feb 25, 2014 11:50 am
Interesting layout for a 2 lane track, might be difficult to follow with allot of the lanes following inside of other lanes. Also, you may want to give some thought to run offs! Most 1/43 track has NO allocation for cars running sideways so some approns are a must. Maybe the adjoining track sould serve as a run off, but honestly I think maybe you are trying to fit to much track in a 4" x 8' space!
Designs of this type are real common in 1/32 and larger scales, because the size of those scale forces you to use as much of the available space as possible, BUT the great thing about 1/43 is you don't need to compact the layout nearly so much. Concentrate more on flow and leave yourself plenty of room for scenic items and you will be much happier!
