Route 66 Rally/Raid layout.
SHOW YOUR SLOT CAR TRACK!
Re: Route 66 Rally/Raid layout.
Postby downtowndeco » Thu Jun 05, 2014 11:23 pm
I added the street & sidewalks for my small town main street scene. The street is masonite, and the sidewalks are cast plaster w/detail carved in. I'm test placing buildings by using cardboard boxes to see how much the sight lines are affected (or not). Basically though buildings/businesses w/line both sides of the intersecting street. Where the main street crosses the slot track there will be stop signs and/or street lights/crosswalks.
Image[/URL]
Image[/URL]
downtowndeco
Postby dreinecke » Fri Jun 06, 2014 9:32 am
Looks good Deco! Did you cast the sidewalks? They look great!
Postby downtowndeco » Sun Jul 06, 2014 6:46 pm
I'm starting on my first structure for my "Main street". The facade is a pair of 1/48th Scale building fronts from a company called Ameritown. I needed to raise it a bit by adding some extra to the bottom because the front doors were too short for 1/32. I then custom built 4 new doors that seem to look pretty good.
Image[/URL]
The right side wall is a hydrocal plaster casting. I hand carved the brick pattern for my line of 1/35 Scale military miniatures, made a rubber mold, made copies & then cut it to fit & added windows. The sign is simply paper applied w/white glue.
Image[/URL]
Image[/URL]
This is the first of 6 or 7 structures that I will scratch build for my "downtown". Questions?
downtowndeco
Postby Ember » Sun Jul 06, 2014 9:16 pm
How thick is your wall cast? I can't get hold of hydrocal (plaster with a small percentage of cement added) without paying a small fortune for shipping, so I attempted plaster cast of a brick facade in plaster from a latex mould with only limited success.
Postby downtowndeco » Sun Jul 06, 2014 10:48 pm
About 1/4". Again, the front of the building is plastic.
If you can't get hydrocal try running small strips of fiberglass drywall mesh into your castings. It adds a lot of strength.
downtowndeco
Postby whitworthnut » Mon Jul 07, 2014 5:40 am
Would 20 minute drywall compound perform the same function as hydrocal. It dries by chemical reaction rather than dehydration. It is about $20 per bag of 20 pounds. It dries very hard and much less dusty than regular dry wall compound.
whitworthnut
Postby downtowndeco » Mon Jul 07, 2014 7:24 am
I don't think so. Hydrocal has pretty unique properties. I have not experimented with many other materials though as I buy hydrocal 500 pounds at a time. My advice? Pay up & get the stuff that works. You'll spend more time messing around than it is worth experimenting than it is worth.
downtowndeco
Postby downtowndeco » Mon Jul 07, 2014 3:09 pm
I glued the two walls together & have placed them tentatively. I will need to add a foundation to bring the structure up to the height of the sidewalk. I also need to figure out what the storefronts will be. Maybe a downtown diner & a bank(?)
Image[/URL]
downtowndeco
Postby whitworthnut » Mon Jul 07, 2014 3:42 pm
Excellent job on the brick work.
whitworthnut
Postby dge467 » Mon Jul 07, 2014 3:49 pm
That looks great!
Postby Ember » Mon Jul 07, 2014 4:32 pm
The larger one looks a little like an old-fashioned department store. The smaller one could pass as a bank if you add some fancy decorations; urns, facade statuary, that sort of thing.
Postby demether » Fri Jul 18, 2014 4:47 pm
Really cool. The weathering on brick is really,really well done. Bravo !
demether
Postby HRWJim » Fri Jul 18, 2014 8:49 pm
Another great building. I second the bravo on the weathering of the brick. Jim
Postby bobbyraz49 » Sat Jul 19, 2014 9:11 am
STUNNING !
bobbyraz49
Postby downtowndeco » Wed Jan 13, 2016 11:26 pm
I'm back. I uncovered the layout, dusted it off & am going to finish it. Here is the beginning of the next structure. This will be an art deco supermarket/drug store. Stay tuned!
Image[/URL]
downtowndeco
Return to Reader's Roads
