Well...it looks like the Boys have a bit of Work lined up for them....the severely damaged Tan '62 Galaxie body, is from an Aurora Vibrator- ie: Pre T-Jet. The body wasn't quite This bad, until, an Asteroid from the sky came down and hit it, can you imagine the chances of THAT happening !?
F.O.R.D. >Found On Roads Dead ! Not quite, but that '62 Galaxie couldn't get much worse- LOL :D Lots of work for the boys this month...and ALL are Fords !
Ruh Roh ! Better Get Maaco :p
Since this pic was taken a few hours ago, the two halves are already rejoined, ie- it was a clean break. I've also repaired the front screw post, and replaced the rear one, which I also lowered both, and also thinned out the underside of the interior tray, so this Vibe Body will sit lower on a T-Jet Chassis :handgestures-thumbup:
PS- I'm looking for the ROOF (Only) from a DASH '63 Ford FAIRLANE, to use on top of the Vibe body. I won't use a DASH '63 Galaxie Roof- as it was different in the contour, and the '63 Fairlane is a Closer match to the '62 Gal. Please contact me if you have a Roof- any color is acceptable, thanks :)
