Home Racing World • View topic - chase-cars update - it takes too long!
Re: chase-cars update - it takes too long!
Postby Ember » Wed Jul 17, 2013 5:04 pm
That George Turner Falcon looks brilliant with some proper lean on it. Oh, I want. I want. I WANT!
And you know you really want to do a Dolly. ;)
Postby olskoolslotz » Wed Jul 17, 2013 5:21 pm
olskoolslotz
"THE Champ"
Postby DHansen » Wed Jul 17, 2013 5:29 pm
Amazing work. Thanks for sharing. I love the Dukes of Hazard jump.
DHansen
Postby dreinecke » Wed Jul 17, 2013 10:46 pm
I know first hand how hard this car and your other ones were to do and also how expensive. Hats off to you for another great creation of something not available in 1:32 ever before. Really awesome stuff!
Postby MoparGreg » Thu Jul 18, 2013 5:16 am
Nice a 71 Plymouth! Your leaning cars look great
MoparGreg
Postby choc-ice » Mon Jul 22, 2013 1:37 pm
Think I need taller body posts. But it does look good as a lowrider!
You won't be surprised that it's getting yellow paint ;)
And the chrome around the front end really helps the look
choc-ice
Postby dreinecke » Mon Jul 22, 2013 5:56 pm
Daisy's car looks great so far. I'd have to paint mine light blue though...
Postby Czar » Mon Jul 22, 2013 7:27 pm
It is really nice to see this endeavor come to fruition. Choc-ice, you are to be commended for your creativity - and perseverance.
Czar
Postby HomeRacingWorld » Mon Jul 22, 2013 7:41 pm
Ditto.
And I am watching this one too. Of all the cars you have made, this mopar is the one for me.
Postby choc-ice » Sat Jul 27, 2013 5:44 am
I cheated a bit with the interior, instead of the normal vacform driver with resin head I put a different figure in
choc-ice
Postby dreinecke » Sat Jul 27, 2013 8:10 am
Looking good!!!
Postby choc-ice » Sat Aug 17, 2013 1:38 pm
I found some early drawings which might be interesting for you to see, it shows the , , fascinating thought process of designing a chassis with steering and suspension.
The first thing was to get an outline of the bodyshell, which I drew up at 2:1 scale. I put on the "fixed" items like motor, tire diameter, rear axle with gear and the steering hubs. You can see the coil springs I had on the rear already.
While doing this, I was sketching up how I thought these parts would work and how they could be manufactured
I then put these onto the CAD system in roughly the correct place
By this stage I was considering torsion bars with adjustable blocks that could slide to make them longer or shorter, the springs softer or harder.
The real benefit of 3D CAD is in 2 things - you can draw up parts and move them around to check for clearances, useful when steering or for suspension. The other advantage is you can create views of your parts and get in amongst it with a pencil!
Front end
Plan view of front end
Motor pod
And in an idle moment, I had some thoughts about logos
choc-ice
Postby RazorJon » Sat Aug 17, 2013 6:09 pm
I like the first one, but it should be leaning over
Postby choc-ice » Sun Sep 01, 2013 3:23 pm
This is the kind of thing I love - using the chassis on someone else's bodyshell. In this case a rally Citroen DS
choc-ice
Postby goosenapper » Sun Sep 01, 2013 5:14 pm
I love this! Given that the hydropneumatic suspension used on these cars was extremely advanced and offered an exceptionally smooth ride for its day, adding your chassis to this car is a fantastic choice.
Did you have to modify your chassis at all to get it to fit under that body? I see where you've shortened the rears axle, but I'm wondering if the wheelbase had to be shortened at all.
goosenapper
