by whitworthnut » Sun Mar 23, 2014 2:50 pm
I knew you would ask that. I cut up a coke can and found that the tin was far too weak. Then I cut up a soup can. The strength was excellent and I was able to curl the end around a pin and created a very convincing, working hinge. Then I did a second which worked equally well, but didn't look quite the same as the first and determined that this is why guys like PST do photo etches. So I threw out both hinges and used masking tape. It works very well, has good strength and is replaceable if needs be and all that is visible is the part that looks like the hinge pin. You just need to make sure that the visible bits are equally spaced as would be hinges. I coloured the visible bits with a black sharpie. The only draw back with using tape is that I can't shoot the inside of the door.
