Home Racing World • View topic - HRW Land Speed & Drag fun run!
Re: HRW Land Speed & Drag fun run!
Postby TuscoTodd » Wed May 13, 2015 7:15 am
Dave -
An option for an inexpensive body would be:
http://www.amazon.com/Revell-851752-For ... B007KMY2WS
(the Anglia body you have sounds like it is 1/24)
Another option you may want to explore is contacting some of the guys here on the boards that are doing resin casting. Lot of possibilities from that angle. :)
In regard to the motors - there are specific motors required for each of the classes - they are detailed out in the first posting - but for the majority of the classes it is the Piranha 21,500 Motor (available through Slot Car Corner, Cloverleaf Racing, etc) - for the slingshot dragsters and the Class A Land Speed cars - it is the H&R Lightning II 40,000 rpm motor (available through various sources)
Hope that helps!
Oh - and one other thing - I misspoke on the manufacturer of the timing system at Mark's Model World on the drag strip - it is a PortaTree Eliminator 2000 Plus system (the other four tracks have Trackmate - sorry for the confusion)
Also - just for reference - a little more of things can be seen in this video from last night...
The video doesn't show the numbers up on the LED display at the end very well - but they are also shown and will be recorded/shared directly off the controller seen in the beginning of the video.
https://www.facebook.com/cantonslotcarr ... =1&theater
Postby TuscoTodd » Wed May 13, 2015 7:18 am
Postby TuscoTodd » Wed May 13, 2015 7:22 am
Postby Racie35 » Wed May 13, 2015 7:57 am
Thankyou Todd
Racie35
Postby TuscoTodd » Wed May 13, 2015 10:01 am
Postby charley » Wed May 13, 2015 11:05 pm
This is great!! I have done a lot of HO "proxy" racing and it's a blast. Have a couple of questions:
1: What are the addresses of the tracks we are to ship to?
2: In what order and dates are the tracks hosting?
3: Can you be more specific on the type of driver that is permitted? ( plastic or lexan painted driver card ), also do they have to be full
bodied drivers or is just a bust with head allowed?
4: Will the cars be shipped to a starting location then after the race, then shipped to the next track or will they be sent back to the owner?
5: I have yet to see a 1/32 Fiat Topolino. Is there any way a 1/25 one be allowed?
6: Are VW' bodies allowed?
Thanks for all the work you are doing to get this going. :clap: I'm looking forward to your reply so I can get things going.
Charley
charley
Postby Ky.Slot Racer » Thu May 14, 2015 5:44 am
there is a vintage fiat kit out there, but t`s a little pricey when they turn up. I purchased the resin copy on eBay in 2013 but that seller is no longer registered.
Ky.Slot Racer
HRW Master Modeler
Postby TuscoTodd » Thu May 14, 2015 10:58 am
Postby TuscoTodd » Thu May 14, 2015 2:09 pm
Postby Racie35 » Thu May 14, 2015 3:07 pm
Thanks for the test data Todd..one question , how tall a tire did you use?
Racie35
Postby TuscoTodd » Thu May 14, 2015 5:14 pm
Postby TuscoTodd » Thu May 14, 2015 7:21 pm
Postby Racie35 » Thu May 14, 2015 7:44 pm
Fiddle diddling with motor shaft height during install...settled on a whisker below axle..got a real smooth mesh..after I make the front motor bracket I'll toss on some parts and test some maybe tomorrow.
I did run this motor some and then at 13v...hard to tell in your hand but it does wind up pretty good.
Racie35
Postby TuscoTodd » Fri May 15, 2015 8:34 am
That is lookin' SWEET!
Two thumbs up sir!!!!
Postby Racie35 » Fri May 15, 2015 11:42 am
Thankyou...I may make a spare for my brother, he likes it too
Racie35
