Home Racing World • View topic - Permanent Go! track...
Postby MikeySlotCars » Mon Aug 10, 2015 8:20 pm
Part 1...
I've been trying multiple layouts (for months) until I came out with something I really like enough to go permanent
Many people might remember my older 3 lanes track that I had before , when I took it apart I was stock with lots of single track lane so I decided to take 2 single lane & clued it (hot glue) together to make back to a 2 lanes track again
Here some pictures...
I use 2x 4"1/2 track to hold the single track together & masking tape so that the glue doesn't go trough the track & glue it to the table...
Turned it upside down & put the glue
Glue dry & tape removed
Once I decided what layout I wanted I started to tight the track joints by using a small flat screw drivers so I can get a better contact all over the layout
Cut some tracks to get the length needed for the layout...
Before putting back the rails on the track you have to make it straight again with long nose pliers
Put back the rails & cut the extras rails out
Next part 2
Mikey
MikeySlotCars
Re: Permanent Go! track...
Postby MikeySlotCars » Mon Aug 10, 2015 8:21 pm
MikeySlotCars
Postby BazingaRacerX » Tue Aug 11, 2015 6:32 am
Nice work. I'm going to be following this thread closely. :banana-dance:
BazingaRacerX
Postby Cjent » Tue Aug 11, 2015 9:33 am
Super work!
Cjent
Postby ourwayband » Tue Aug 11, 2015 10:33 am
Now there is a track.Looks great.
Postby TuscoTodd » Tue Aug 11, 2015 4:00 pm
WOW!!!!
Not only a GREAT looking / flowing track - but AWESOME tutorial pictures on modifying track sections and making flowing aprons!
VERY cool!!!
Thank you for sharing!
:text-bravo:
Postby MikeySlotCars » Tue Aug 11, 2015 6:53 pm
Thanks! guys...
I always appreciated when people take the time to respond to the work I've done it makes me fell good & encourage me to do/show some more... thanks! again guys
Next under the table power taps wiring hopefully all done by tonight...
Stay tuned...
BTW: The foam board borders (Aprons) that I'm using right now is only to give me an idea on how it will looks like , the borders are going to be made out of 1/4" MDF
Mikey
MikeySlotCars
Postby TuscoTodd » Tue Aug 11, 2015 7:51 pm
I still really like that two pin/pencil jig set up! That is just plain slick!
Postby dreinecke » Tue Aug 11, 2015 9:51 pm
Really great looking track and the way you did the borders is genius!
Postby loosesalute » Wed Aug 12, 2015 1:38 am
Yes, and the grey track looks ace! :banana-dance:
Kev
loosesalute
Postby MikeySlotCars » Wed Aug 12, 2015 11:13 pm
Thanks! guys...
Power taps wiring is finally done , it was a much longer job then I though it would be , anyhow lets start the pictures...
I was having a hard time finding screw terminal in store near home or when I found one it was to expensive IMO so I came up with the idea of using phone jacks terminal it works great & cheap to buy
Here the phone jacks terminal & wire that I bought
Now I just had to remove the phone wire from the terminal & replace the screws in another hole to make some room between the wire connections
I marked lane #1&2 at every track that I have a power taps connected to & also under the table , I also marked the wires so I don't get them mixed up...
Now the fun of working under the table begins...
Here is where the power taps are located on the layout
BTW: The power supply & controllers are only temporary for now
Next the borders (aprons)...
Mikey
MikeySlotCars
Postby TuscoTodd » Thu Aug 13, 2015 8:46 am
LOVE all the detail pictures on this thread! Great stuff!
Postby Dodgefarmer » Thu Aug 13, 2015 9:24 am
Phone jacks! Thank you Mickey. :) That is 1 super setup for sure. This thread is going to be a "Huge" help on my next track.
Randy
Dodgefarmer
Postby MikeySlotCars » Thu Aug 13, 2015 11:41 pm
MikeySlotCars
Postby Dodgefarmer » Fri Aug 14, 2015 12:26 am
I used Masonite (hardboard) for my aprons. The masonite and 1 layer of construction paper is almost perfect.
Randy
Dodgefarmer
