inner curve borders on HO scale tracks
HO Scale Slot Car Forum
Postby qball41 » Fri Sep 04, 2015 5:49 pm
I'm curious to learn what others have used for inner borders on turns on their HO scale layouts.
I would love to find something about a 1/4" that would be flexible so I could form it to the corner.
Any ideas you have seen used would be appreciated.
qball41
Re: inner curve borders on HO scale tracks
Postby vins123 » Fri Sep 04, 2015 7:10 pm
Hi
Tyco ever made some -- 5871-2 from u turn set, or
just go under ho AFX speedway from another member you will see some marvelous things
Sylvain
vins123
Postby BIG E » Fri Sep 04, 2015 7:19 pm
Best to just cut the material to fit inside the corner, instead of trying to bend something around to fit. 1/4" masonite or corkboard painted black works well. I believe Brad Bowman is making aprons for HO sectional tracks, you'd have to check his website for actual details and availability. -- Ernie :>)
BIG E
Postby Shadowracer » Thu Sep 10, 2015 10:35 pm
Ho scale cork track bed (for trains) works great. It's flexible and pretty cheap too.
Shadowracer
Postby qball41 » Sun Sep 13, 2015 8:20 pm
Cork roadbed is what I went with. It worked well. I'll post some pictures soon.
qball41
Postby mrstumpyHO » Mon Oct 19, 2015 7:19 pm
I used Tomy track with O scale cork railroad roadbed because it was the right thickness for the track. On the inside of 6" radius curves the O scale was too wide and tough to bend right, so I stacked HO roadbed to get the right height. You can use card stock or poster board to shim the roadbed to the perfect level too.
Stumpy Stone :banana-dance:
mrstumpyHO
Return to HRW HO Scale
