Home Racing World • View topic - Bugatti Atalante
Bugatti Atalante
Re: Bugatti Atalante
Postby Ember » Mon Nov 18, 2013 7:09 pm
I have one Jag that would not give me a good gloss finish no matter how much I drowned it in clear. I finished up wet sanding it smooth with 2000 grade wet'n'dry then buffed it through the 3 grades of Tamiya polishing compound. It's now mirror finish. But still not as glassy as Dave's 2 pack urethane finish.
Postby whitworthnut » Mon Nov 18, 2013 7:17 pm
Very hard to sand this one all over without losing detail with too many additional coats. There are lots of louvres and Pyro's details are easily lost. Beyond the sag, the finish is great. It looks like a candy (no it's not red).
whitworthnut
Postby Ember » Mon Nov 18, 2013 7:49 pm
Where is the dribble/sag? Should be able to just sand that spot and polish it out.
Postby whitworthnut » Mon Nov 18, 2013 7:56 pm
It's on the door panel. By sand and polish, do you mean wax or compound?
whitworthnut
Postby whitworthnut » Mon Nov 18, 2013 8:57 pm
Thanks Dave. Yes, there are lines around the door panel so I can do just that section.
whitworthnut
Postby Ember » Mon Nov 18, 2013 9:00 pm
Polishing compound. If you have a light touch T-cut will do a good job. It is a cut and polish compound for auto paints.
Postby whitworthnut » Tue Nov 19, 2013 6:00 pm
whitworthnut
Postby whitworthnut » Thu Nov 28, 2013 5:37 pm
whitworthnut
Postby Ember » Thu Nov 28, 2013 6:12 pm
Not what i expected at all, but it suits it handsomely. The colour makes it look more a purposeful tourer and much less a frivolous cocktail chaser. Beautiful work, just as we have come to expect from you.
Postby whitworthnut » Fri Nov 29, 2013 6:51 pm
whitworthnut
Postby whitworthnut » Sun Dec 01, 2013 7:25 am
whitworthnut
Postby Dundee Denny » Sun Dec 01, 2013 8:21 am
What you have created looks like a piece of art that should be in a museum!
One of the very top builds I have seen on the site!!
CONGRATS!!
Dundee Denny
Dundee Denny
Postby Ember » Sun Dec 01, 2013 3:45 pm
What glue(s) do you use on the static kits Peter?
Postby whitworthnut » Sun Dec 01, 2013 4:11 pm
I use a variety. If I can tack with cyanocrylc, I'll do that. If a less forgiving area, I'll use plastic cement (Testors). I then re-inforce with two part epoxy for strength.
whitworthnut
Postby Ember » Sun Dec 01, 2013 4:17 pm
I've got some MicroMark "Same stuff" to try, which seems to be a solvent weld. Glues always seem to be such a bit question mark in slot car building.
