Home Racing World • View topic - Go!replacement chassis, fully customicable - it´s running!
Re: Go!replacement chassis, fully customicable
Postby pfuetze » Mon Feb 24, 2014 4:52 am
Postby pfuetze » Mon Feb 24, 2014 4:54 am
And in the meantime there is some additional information:
to get the guide deeper into the chassis, if the front wheels don´t touch the track, there is the possibility to cut the ring under the guide holder:
found a drawing of a chip, if this is maybe of interest?
Postby Cjent » Mon Feb 24, 2014 8:03 am
Thanks, Peter! This will work so well! :D
Cjent
Postby Alan132 » Mon Feb 24, 2014 8:34 am
Peter,
Thank you very much for posting the additional information. That about covers it except for one more item.
What is the thickness of the guide blade? Side to side measurement.
This helps a lot!
Thank you
Alan
Alan132
Postby Alan132 » Mon Feb 24, 2014 8:48 am
Peter,
Something is not right and it is most likely me however when I add the measurements up for the wheels base and the other two you supplied they do not add up to the over all length. This is for both the min and max configurations.
Thank you
Alan
Alan132
Postby pfuetze » Mon Feb 24, 2014 8:57 am
Thickness of the guide blade: 1.9mm
front measurement: 6.5mm
rear measurement: 9mm
same measurements for min and max. configuration
sometimes, i get the wrong point when 3D measuring and than this sh.t happens. sorry for the wrong values and pics.
Peter
EDIT: i exchange the pics above to the correct ones.
Postby Alan132 » Mon Feb 24, 2014 12:34 pm
Hello Peter,
Thanks again for the corrections and quick reply. Now off to see what bodies need chassis!
Darn - forgot to ask.
What motor is this setup for?
Alan
Alan132
Postby pfuetze » Mon Feb 24, 2014 1:37 pm
Alan, this chassis has been designed to accept the Go!motor or the SCX motor, along with the drive train.
It will take a RadioShack motor, too or any other FF030 motor.
Peter
Postby BRS Hobbies » Mon Feb 24, 2014 1:49 pm
Peter,
The chassis looks awesome! Would you be able to modify the chassis so the guide blade sits deeper in the chassis? I would rather shim the guide with a washer so it is further away from the chassis (if needed), than to trim the chassis which could be a little more challenging to keep the material level where the guide sits against it.
Best regards,
Brian
BRS Hobbies
Postby Alan132 » Mon Feb 24, 2014 2:37 pm
Peter,
I thought so was not 100% sure. Just ordered 50 ea of the FF-030 motors!
Looking forward to the updated measurements.
Many thanks
Alan
Alan132
Postby pfuetze » Mon Feb 24, 2014 3:16 pm
Brian, the chassis is shown with 15mm wheels. Most Go!tires are bigger, the biggest ones being 20mm. If i shorten the guide holder, the guide will sit too high in the chassis. When shimmed, the guidiance gets more wobbly and i don´t like that. From the technical point of view it is not necessary to have the surface 100% level and the longer guide length helps to avoid wobble.
And there is a real ring with only thin walls on the under side, which should be easy to cut. You don´t have to really cut material and become it level, only removing a ring.
I will post a photo as soon as i get the first prototype to show what i mean.
Peter
Postby Alan132 » Mon Feb 24, 2014 3:44 pm
Hi Peter,
New figures still do not add but but close enough. Still 1mm off but not an issue. These will get me in the ball bark!
If I would like the option rear mount just indicate then when I send you the measurements?
Based on the standard sized chassis it appears to be around $16.00 US. Will that be true for the chassis no matter what measurements are submitted to you?
Regards - Alan
Alan132
Postby pfuetze » Tue Feb 25, 2014 1:27 am
okay, i forgot to update the overall measurement. now it should be okay.
If you like the rear mount, just add it to the measurements "including rear mount option"
for the price - it will change a little depending on the material used during printing, this is due to shapeways.
Ciao,
Peter
Postby Dodgefarmer » Tue Feb 25, 2014 10:08 am
Alan,where did you order the motors from?
Randy
Dodgefarmer
Postby Alan132 » Tue Feb 25, 2014 4:15 pm
Randy,
Direct from Mabuchi. Missed a zero on the Qty when I posted. Got 500 ea coming in. Using them for slots and other things.
Alan
Alan132
