Home Racing World • View topic - HRW NASCAR Cup Proxy.. Cars Due Nov. 15th
Re: 2014 HRW NASCAR Cup Proxy
Postby Audi1 » Sat May 03, 2014 4:26 am
OK, I'm in with a variation of the Earnhardt Jr. National Guard Chevy COT (I think I got the COT part right..........) It comes as #88 and I see that number's gone already, so I'll need to get some tips from Bibbster on how to strip and re-paint a NASCAR body; or, at least re-number it. I think that the due date is July 11th - right?
Number 19, please.
Dickie, I'll pick up one of those car from you when we race at SCC tonight.
Postby SRQSloter » Sat May 03, 2014 6:49 am
Sounds good Audi. Due date not set it stone yet may be a week or two later but not sooner. To strip the body you can soak it 91% alcohol for while. Then wash it with soap and water sand and prime.
SRQSloter
Postby Audi1 » Sun May 04, 2014 8:02 am
Purchased my car last night from Dickie at SCC. We ran a 3 hour enduro that was a lot of fun.
Now I'm thinking about the 91% isopropyl alcohol bath for the body. I'm going to cruise Brian Patto's Place to see if I can fine a livery that's simple and that I like for this Chevy Impala COT car.
Postby arroldn » Sun May 04, 2014 4:14 pm
I would like #9 Dodge Dealers Dodge and #17 DeWalt Ford Taurus. Since this race is so far off I may have time to paint a Ford or Chevy sidewinder to make it a Dodge so could I also reserve #43?
arroldn
Postby SRQSloter » Sun May 04, 2014 5:42 pm
Hi Arroldn, Think I'll keep it to just two entries per. But I will keep you in for the three numbers till you decide which two.
Thanks
SRQSloter
Postby arroldn » Sun May 04, 2014 8:03 pm
Thanks Rusty. Would like to run Dodges if possible.
arroldn
Postby SRQSloter » Sun May 04, 2014 9:17 pm
10-4 on the Dodges. :handgestures-thumbup:
SRQSloter
Postby Audi1 » Mon May 26, 2014 6:25 am
Is the minimum chassis clearance really 0.062"? That's well over 1mm if my math is correct (25.4mm = 1 inch). So, 0.062" = 1.58mm.
Seems high to me..............
Postby SRQSloter » Mon May 26, 2014 6:36 am
SRQSloter
Postby Austin » Mon May 26, 2014 2:00 pm
At the camp this weekend and was working on this
Motor and gears on the way
No rules with me so I put the weight under the chassis now see it needs it go inside
Austin
Postby SRQSloter » Mon May 26, 2014 2:41 pm
Yes the weight needs to go inside the chassis.
SRQSloter
Postby Audi1 » Mon May 26, 2014 4:49 pm
Postby Audi1 » Sun Jun 08, 2014 8:12 pm
Was this proxy run last year? If yes, are the results published somewhere on the forum and is there technical information on each of the cars in that proxy available?
Postby SRQSloter » Mon Jun 09, 2014 1:54 am
SRQSloter
Postby Retro Racer 44 » Tue Jun 10, 2014 1:24 am
Sorry I snagged the #88. An easy fix would be to ask for 188 and add a one in front of the number.
The best way to check your clearance is to roll a piece of 1/16 piano wire under the car. If it hits anything, it's sitting too low. Usually this rule does not include the spur gear on a sidewinder as long as it doesn't rub on the track.
Retro Racer 44
